Paginator from CCv5 doesn't work
9 Jahre 11 Monate her #2633 von Dirk
Hi
I use the component ChronoConnectivity v5 at my site for display some database tables..
One of the options from that component is that the paginator function can be used.
But this option doesn't qua styling not properly.... It works... oke.. that's fair but the displaying not correct.
It displaying oke in an another template but not in this one
how to fix this problem
see the image for details
thnx in advance
9 Jahre 11 Monate her #2634 von Matthias
Hi,
if I get the link to a page with this problem, I should be able to find the reason for this bad layout :) .
Matthias
9 Jahre 11 Monate her #2635 von Dirk
9 Jahre 11 Monate her #2636 von Matthias
The following CSS-Code should solve the problem:
#maincontent .gbs3 ul.pagination li.item { padding: 0; border: none; }
9 Jahre 11 Monate her #2637 von Dirk
I add the code to the custom code but sorry.. it doesn't fit the issue
9 Jahre 11 Monate her #2638 von Matthias
Did you added the code in the active Style of the template?
Did you saved the changes?
I can not see the added CSS-Code.
Ladezeit der Seite: 0.403 Sekunden
